BT.com
Wishlist
Kingston DataTraveler 100 G2 - USB flash drive - 32 GB - USB 2.0 - black
Delivery
Standard Due date unavailable
DataTraveler 100 G2 is a stylish drive built with simplicity in mind, allowing you to focus on your data. High quality components maintain the legendary Kingston reliability and the USB connector is safely housed inside the sleek and durable case. Carry all of your documents with you, wherever you go.
Built with simplicity in mind, DataTraveler 100 features a sliding capless design with the USB connector safely housed inside the sleek case, so you won't worry about losing a cap. DataTraveler 100 is available in large capacities to give you plenty of room for all your documents, photos, MP3 files and video clips.
USB flash drive
Interface Type
USB 2.0
Storage Capacity
32 GB
Enclosure Colour
Microsoft Windows 2000 SP4, Linux 2.6.x or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5.x or later
5 years warranty
USB flash drive
Storage Capacity
32 GB
Enclosure Colour
Compatibility
Non-specific
Read Rate
Up to 10 MB/s
Write Rate
Up to 5 MB/s
Interface Type
USB 2.0
Retractable connector
Plug and Play
5 years warranty
Service & Support Details
Limited warranty - 5 years
69.6 mm
22.4 mm
12.8 mm
60 °C
Scroll to top
