BT.com
Wishlist
Kingston 8GB microSD UHS-I Industrial Temperature
Kingston 8GB microSD UHS-I...
£7.06
30 left in stock
£7.06
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Tuesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Kingston's industrial temperature microSD UHS-I has a wide operating temperature rating, making it suitable for harsh environments. It high operating temperature rating means it stands up to extreme heat in the desert and in test and measurement situations where standard microSD cards may fail, while its low operating temperature rating allows for use in below freezing weather, where equipment may be left outside for extended periods of time. Its high insertion rating is ideal for applications in which the card will be frequently accessed and removed from host devices, and its MLC NAND allows for large amounts of data to be written to the card.
With UHS-I speeds, the card is ideal for applications requiring greater bandwidth when recording large datasets. Higher sustained write speeds ensure data integrity by reducing transmission stutter, and the card also offers faster upload times when transferring files to a PC.
Kingston - flash memory card - 8 GB - microSDHC UHS-I
Flash memory card
microSDHC UHS-I Memory Card
Storage Capacity
8 GB
Speed Rating
UHS Class 1 / Class10
MLC NAND Flash
5 years warranty
Flash memory card
Storage Capacity
8 GB
Compatibility
Non-specific
SD Speed Class
Read Rate
Up to 90 MB/s
Write Rate
Up to 20 MB/s
MLC NAND Flash
Limited warranty - 5 years
11 mm
15 mm
Thickness
1 mm
-40 °C
85 °C
Scroll to top
