BT.com
Wishlist
Kingston 8GB IronKey D250 Basic FIPS USB 2.0
Delivery
Standard Due date unavailable
Designed specifically for enterprise, government and military customers that need high performance and reliability in their USB flash storage devices, IronKey Basic D250 flash drive meets the extreme performance and security requirements of some very demanding organizations. It is equipped with strong hardware encryption. A ruggedized, waterproof metal chassis helps protect D250 drive from the elements, and active anti-malware prevents USB threats from spreading.
IronKey Basic D250 - USB flash drive - 8 GB
USB flash drive
Interface Type
USB 2.0
Storage Capacity
8 GB
Hardware Encryption
Encryption Algorithm
FIPS 140-2 Level 3, 2048-bit RSA, 256-bit SHA, 256-bit AES-CBC
MLC NAND Flash
Microsoft Windows Vista SP2, Linux 2.6 or later, Microsoft Windows 7 SP1, Windows 8, Apple MacOS X 10.9 - 10.11, Windows 8.1 / 10
5 years warranty
USB flash drive
Storage Capacity
8 GB
Hardware Encryption
Compatibility
Non-specific
Read Rate
Up to 29 MB/s
Write Rate
Up to 13 MB/s
Interface Type
USB 2.0
MLC NAND Flash
Password protection, waterproof, tamper-proof, ruggedized, metal body, Cryptochip
Limited warranty - 5 years
75 mm
19 mm
9 mm
25 g
70 °C
Scroll to top
