BT.com
Wishlist
Kingston 8GB DDR4 SO-DIMM 260-pin 2133 MHz/PC4-17000 - CL15 - 1.2V - Unbuffered - ECC
Kingston 8GB DDR4 SO-DIMM 260-pin...
£104.86
Hurry, only 3 left in stock!
£104.86
Add to wishlist
Delivery
Standard 1-3 working days
Kingston manufacture the most reliable memory you can buy for a HP Server. Kingstons legendary reputation is built around reliable memory, that will power your HP server with ease, whether it be for minimal day hours or an enviroment that requires 24/7 uptime all year round. Kingston's legendary reputation is also reflected with the peace of mind of a full lifetime warranty on this HP compatible memory module.
  • for HP ZBook 15 G3 Mobile Workstation, 17 G3 Mobile Workstation, Studio G3 Mobile Workstation
Kingston - DDR4 - 8 GB - SO-DIMM 260-pin
RAM memory
8 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Unbuffered
Voltage
1.2 V
Lead Plating
Gold
HP V1D58AA
Limited lifetime warranty (Russia - 10 years)
8 GB
Upgrade Type
System specific
HP V1D58AA
DRAM
DDR4 SDRAM
SO-DIMM 260-pin
Speed
Latency Timings
CL15
ECC
Unbuffered
Module Configuration
1024 X 72
Voltage
1.2 V
Lead Plating
Gold
Scroll to top
