BT.com
Wishlist
Kingston 8GB DDR4-2133MHz ECC Module
Kingston 8GB DDR4-2133MHz ECC...
£99.57
£99.57
Add to wishlist
Delivery
Standard Due date unavailable
Kingston memory is designed, manufactured and rigorously tested to meet the exact specifications of each brand name system. It’s guaranteed to be compatible and backed by a lifetime warranty and legendary Kingston reliability.
Kingston - DDR4 - 8 GB - DIMM 288-pin
RAM memory
8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Unbuffered
Voltage
1.2 V
Lead Plating
Gold
Lenovo 4X70K14184
Limited lifetime warranty (Russia - 10 years)
Lenovo ThinkStation P310 30AS, 30AT, 30AU, 30AV
8 GB
Upgrade Type
System specific
Lenovo 4X70K14184
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15
ECC
Unbuffered
Module Configuration
1024 X 72
Voltage
1.2 V
Lead Plating
Gold
Scroll to top
