BT.com
Wishlist
Kingston 8GB DDR4-2133MHz ECC Module
Kingston 8GB DDR4-2133MHz ECC...
£84.69
10 in stock
£84.69
Add to wishlist
Delivery
Standard 3-5 working days
Kingston memory is designed, manufactured and rigorously tested to meet the exact specifications of each brand name system. It’s guaranteed to be compatible and backed by a lifetime warranty and legendary Kingston reliability.
Kingston - DDR4 - 8 GB - DIMM 288-pin
RAM memory
8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Unbuffered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
Dell PowerEdge R230, R330, T130, T330
8 GB
Upgrade Type
System specific
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15
ECC
Unbuffered
Module Configuration
1024 X 72
Voltage
1.2 V
Lead Plating
Gold
£84.69
Save on this ideal PC Build kit!
Save £8.40
£103.91
Scroll to top
