BT.com
Wishlist
Kingston 8GB DDR3L DIMM 240-pin 1600 MHz/PC3-12800 CL11 1.35 V Registered ECC Memory Module
Delivery
Standard Due date unavailable
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR3L - 8 GB - DIMM 240-pin
RAM memory
8 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11
Temperature monitoring, dual rank, registered
Voltage
1.35 V
Lead Plating
Gold
8 GB
Upgrade Type
Generic
DRAM
DDR3L SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11
ECC
Module Configuration
1024 X 72
Chips Organization
X8
Voltage
1.35 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
Scroll to top
