BT.com
Wishlist
Kingston 8GB DDR3 1600MHz CL11 DIMM Memory
Kingston 8GB DDR3 1600MHz CL11 DIMM...
£82.51
5 in stock
£82.51
Add to wishlist
Delivery
Standard 3-5 working days
Kingston - DDR3L - 8 GB - DIMM 240-pin - 1600 MHz / PC3L-12800 - CL11 - 1.35 V - unbuffered - ECC
RAM memory
8 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
1600 MHz (PC3L-12800)
Latency Timings
CL11
Dual rank, Low Voltage, unbuffered
Voltage
1.35 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
8 GB
Upgrade Type
Generic
DRAM
DDR3L SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11
ECC
Module Configuration
1024 X 72
Chips Organization
X8
Voltage
1.35 V
Lead Plating
Gold
£82.51
Save on this ideal PC Build kit!
Save £8.40
£101.73
Scroll to top
