BT.com
Wishlist
Kingston 8GB DDR3 1333MHz CL9 DIMM Memory
Kingston 8GB DDR3 1333MHz CL9 DIMM...
£82.51
18 in stock
£82.51
Add to wishlist
Delivery
Standard 3-5 working days
Kingston - DDR3 - 8 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - CL9 - 1.5 V - unbuffered - ECC
RAM memory
8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
1333 MHz (PC3-10600)
Latency Timings
CL9
Dual rank, unbuffered
Voltage
1.5 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9
ECC
Module Configuration
1024 X 72
Chips Organization
X8
Voltage
1.5 V
Lead Plating
Gold
£82.51
Save on this ideal PC Build kit!
Save £8.40
£101.73
Scroll to top
