BT.com
Wishlist
Kingston 8GB 1600MHz Reg ECC Low Voltage Module
Delivery
Standard 3-5 working days
Designed with your specific system in mind, Kingston system-specific memory makes it easy to select exactly what you need, based on your OEM system brand and model. Kingston engineers use only the highest quality components on the market to ensure maximum performance and legendary Kingston reliability. All Kingston system-specific memory is guaranteed to be compatible with the system for which it was designed – which takes the hassle out of selecting memory for your notebook or desktop.
Kingston - DDR3 - 8 GB
RAM memory
8 GB
Memory Type
DDR3 SDRAM
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1600 MHz (PC3-12800)
Low Voltage, registered
8 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
Speed
ECC
Compatible Slots
1 x memory
Scroll to top
