BT.com
Wishlist
Kingston 8GB 1600MHz DDR3 Non-ECC CL9 DIMM Kit of 2 XMP HyperX Savage
Kingston 8GB 1600MHz DDR3 Non-ECC...
£60.10
More than 50 in stock
£60.10
Add to wishlist
Delivery
Standard 3-5 working days
Marketing description is not available.
HyperX Savage - DDR3 - 8 GB : 2 x 4 GB - DIMM 240-pin
RAM memory
8 GB : 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz ( PC3-12800 )
Latency Timings
CL9 ( 9-9-9 )
Single rank, eight banks, aluminium heat spreader, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), dual channel, Black PCB, red heat spreader, low profile heat spreader, asymmetrical heatspreader , unbuffered
Voltage
1.5 V
Lead Plating
Gold
Limited lifetime warranty ( Russia - 10 years )
8 GB : 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.29
Speed
Latency Timings
CL9 ( 9-9-9 )
Non-ECC
Module Configuration
512 x 64
Chips Organization
512 x 8
Voltage
1.5 V
Lead Plating
Gold
Colour Category
Red
Kingston 8GB 1600MHz DDR3 Non-ECC CL9 DIMM Kit of 2 XMP...
£60.10
Save on this ideal PC Build kit!
Save £9.28
£79.69
Scroll to top
