BT.com
Wishlist
Kingston 8GB 1333MHZ ECC Module
Delivery
Standard Due date unavailable
Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
Kingston - DDR3L - 8 GB - DIMM 240-pin
RAM memory
8 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1333 MHz ( PC3-10600 )
Low Voltage , registered
Limited lifetime warranty ( Russia - 10 years )
Gateway 1000-GW170 F1, 1000-GW170q F1, 2000h-GW170h F1, 2000h-GW170hq F1, 2000h-GW175h F1, 2000h-GW175hq F1, 2000ht-GW170ht F1, 2000ht-GW170htq F1, GR160 F1, GR180 F1, GR360 F1, GR380 F1, GR385 F1, GR585 F1, GT150 F1, GT350 F1, GT350 F1-TM; NEC Express5800; SGI Altix XE270
8 GB
Upgrade Type
System specific
DRAM
DDR3L SDRAM
DIMM 240-pin
Speed
ECC
Compatible Slots
1 x memory - DIMM 240-pin
Gateway 1000-GW170 F1, 1000-GW170q F1, 2000h-GW170h F1, 2000h-GW170hq F1, 2000h-GW175h F1, 2000h-GW175hq F1, 2000ht-GW170ht F1, 2000ht-GW170htq F1, GR160 F1, GR180 F1, GR360 F1, GR380 F1, GR385 F1, GR585 F1, GT150 F1, GT350 F1, GT350 F1-TM , NEC Express5800 B120a, B120a-d, B120b, B120b-d, B120b-h, R120a-1, R120a-2, R120b-1, R120b-2, R140b-4, R320a-E4, R320a-M4, T120a-E, T120b-E, T120b-M , SGI Altix XE270
Scroll to top
