BT.com
Wishlist
Kingston 8GB 1333MHZ DDR3L ECC REG CL9
Kingston 8GB 1333MHZ DDR3L ECC REG...
£68.83
10 in stock
£68.83
Add to wishlist
Delivery
Standard 3-5 working days
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR3 - 8 GB - DIMM 240-pin
RAM memory
8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
1333 MHz (PC3-10600)
Latency Timings
CL9
Temperature monitoring, dual rank, registered
Voltage
1.5 V
Lead Plating
Gold
8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9
ECC
Module Configuration
1024 X 72
Chips Organization
X8
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
£68.83
Save on this ideal PC Build kit!
Save £10.63
£88.00
Scroll to top
