BT.com
Wishlist
Kingston 8GB 1333MHz DDR3L ECC CL9 SODIMM 1.35V
Kingston 8GB 1333MHz DDR3L ECC CL9...
£70.70
6 in stock
£70.70
Add to wishlist
Delivery
Standard 3-5 working days
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR3L - 8 GB - SO-DIMM 204-pin
RAM memory
8 GB
Memory Type
DDR3L SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
1333 MHz (PC3-10600)
Latency Timings
CL9
Low Voltage, unbuffered
Voltage
1.35 V
Lead Plating
Gold
8 GB
Upgrade Type
Generic
DRAM
DDR3L SDRAM
SO-DIMM 204-pin
Speed
Latency Timings
CL9
ECC
Module Configuration
1024 X 72
Voltage
1.35 V
Lead Plating
Gold
Compatible Slots
1 x memory - SO-DIMM 204-pin
£70.70
Save on this ideal PC Build kit!
Save £8.43
£89.92
Scroll to top
