BT.com
Wishlist
Kingston 8GB (kit)
Kingston 8GB (kit)
Delivery
Standard Due date unavailable
All Kingston® memory modules must perform properly to ensure maximum performance. Therefore, Kingston has developed an industry leading quality process to ensure that Kingston memory delivers superior quality, performance, and 100% compatibility with the computing system the module is designed for. Kingston, the world's largest independent memory manufacturer, has over 2, 000 memory products. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
Kingston - DDR2 - 8 GB: 2 x 4 GB - FB-DIMM 240-pin
RAM memory
8 GB: 2 x 4 GB
Memory Type
DDR2 SDRAM - FB-DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
667 MHz (PC2-5300)
Fully Buffered
Voltage
1.8 V
Sun X4204A, Sun SESX2C1Z
Limited lifetime warranty (Germany, Austria and France - 10 years)
Sun Blade T6320 Server Module; Netra T5440; SPARC Enterprise T5120, T5140, T5220, T5240, T5440
8 GB: 2 x 4 GB
Upgrade Type
System specific
DRAM
DDR2 SDRAM
FB-DIMM 240-pin
Speed
667 MHz (PC2-5300)
ECC
Fully Buffered
Voltage
1.8 V
Compatible Slots
2 x memory - FB-DIMM 240-pin
Sun Blade T6320 Server Module , Sun Netra T5440 , Sun SPARC Enterprise T5120, T5140, T5220, T5240, T5440
Scroll to top
