Click to visit BT.com
BT.com
Wishlist
Kingston 8GB (2 x 4GB) HyperX Genesis DDR3 1600MHz DIMM 240-pin CL9 XMP
5.0*
Quicklinx: 7N58WS00
Mfr#: KHX1600C9D3K2/8GX
8GB 1600MHz DDR3 Non-ECC CL9 DIMM (Kit of 2) XMP
Kingston proudly introduces HyperX DDR3 memory, the latest generation of DDR memory technology. Like all Kingston HyperX products, DDR3 modules are specifically engineered and designed to meet the rigorous requirements of PC enthusiasts. DDR3 memory offers faster speeds, lower latencies, higher data bandwidths and lower power consumption than DDR2.
This dual-channel HyperX memory kit is Intel XMP-Certified, and runs at a latency timing of 9-9-9-27 at 1.65V operating voltage for dual-channel platforms.
MOVE AT THE SPEED OF X
Kingston Technology, the world's independent memory leader, proudly offers HyperX® memory for gamers and PC enthusiasts. HyperX modules are specifically engineered and tested for higher speeds and lower latencies. HyperX is available in five distinct product lines to meet the specific needs of everyone from the entry-level gamer to the seasoned pro. Kingston® HyperX Genesis sets the standard for high-performance memory. It offers greater thermal performance, higher frequency speed and lower latency and is ideal for gamers, enthusiasts, system integrators and anyone who wants to maximize their hardware.
FEATURES/SPECS
  • High-performance memory
  • Ideal for gamers, enthusiasts and system integrators
  • Capacities: 8GB, Kit of 2
  • Frequency speed: DDR3 1600MHz
  • Operating Temperature: 0°C to 85°C
  • Storage Temperature: 55°C to 100°C
  • Dimensions: 133.35mm X 30mm
  • CAS Latency: CL9
  • Voltage: 1.65V
  • Intel XMP Ready - higher performing frequencies, timings and voltage attainable by simply enabling Intel's Extreme Memory Profile
  • Compatible - tested with all popular brands of motherboards
  • Reliable 100% tested
  • Easy to install
  • Guaranteed lifetime warranty, 24/7 live technical support
Kingston's KHX1600C9D3K2/8GX is a kit of two 512M x 64-bit (4GB) DDR3-1600 CL9 SDRAM (Synchronous DRAM) 2Rx8 memory modules, based on sixteen 256M x 8-bit DDR3 FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 8GB. Each module kit has been tested to run at DDR3-1600 at a low latency timing of 9-9-9-27 at 1.65V. The SPDs are programmed to JEDEC standard latency DDR3-1333 timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V.
Kingston HyperX - DDR3 - 8 GB : 2 x 4 GB - DIMM 240-pin
RAM memory
8 GB : 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz ( PC3-12800 )
Latency Timings
CL9
Intel Extreme Memory Profiles (XMP), dual channel , unbuffered
Voltage
1.65 V
Lead Plating
Gold
8 GB : 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9
Non-ECC
Module Configuration
512 x 64
Voltage
1.65 V
Lead Plating
Gold
Compatible Slots
2 x memory - DIMM 240-pin
Resources
The following resources are available for the Kingston 8GB (2 x 4GB) HyperX Genesis DDR3 1600MHz DIMM 240-pin CL9 XMP
Customer reviews
Write a review for the Kingston 8GB (2 x 4GB) HyperX Genesis DDR3 1600MHz DIMM 240-pin CL9 XMP here!
good memory
Reviewed by Charlie Booker. Review Posted 03/02/2012
not fancy just does what its meant to do!
the only time this memory got full and took along time to load programs was after a full 28 hours of on time downloading big files, playing games, loading up various programs and rendering a HD video!
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
