BT.com
Wishlist
Kingston 8GB (2 x 4GB) HyperX DDR3 1600MHz DIMM 240-pin CL9 XMP Grey
Delivery
Standard Due date unavailable
Kingston's KHX1600C9D3X2K2/8GX is a kit of two 512 M x 64-bit DDR3-1600MHz CL9 SDRAM (Synchronous DRAM) memory modules, based on sixteen 256 M x 8-bit DDR3 FBGA components per module. Each module kit supports Intel XMP (Extreme Memory Profiles). Each module kit has been tested to run at DDR3-1600 MHz at low latency timing. The SPDs are programmed to JEDEC standard latency DDR3-1333MHz timing.
HyperX Genesis XMP X2 Grey Series - DDR3 - 8 GB: 2 x 4 GB - DIMM 240-pin
RAM memory
8 GB: 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL9
Heat sink, eight banks, On-Die Termination (ODT), Serial Presence Detect (SPD), Intel Extreme Memory Profiles (XMP), dual channel, unbuffered
Voltage
1.65 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
8 GB: 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9
Non-ECC
Module Configuration
512 x 64
Voltage
1.65 V
Lead Plating
Gold
Compatible Slots
2 x memory - DIMM 240-pin
Scroll to top
