Prey on the competition.
Game play just got more aggressive with extreme speeds and low latencies for unbeatable DDR4 performance. HyperX® Predator DDR4 complements Intel’s 2, 4, 6 or 8 core processors for faster video editing, 3D rendering, gaming and AI processing. It’s XMP ready and XMP certified and available in CL12–CL16 latencies and in 16GB, 32GB and 64GB kits in speeds of up to 3000MHz. 16GB modules in kits of 2 and 4 are also available.
HyperX Predator DDR4’s Intel XMP-ready profiles are optimised for Intel 100 series and X99 series motherboards. Hand-tuned XMP profiles are built directly into the modules, so users can easily overclock their platforms by simply selecting a profile, with no need for manual timing adjustments in BIOS.
Predator DDR4 keeps its cool while gaming, with a low 1.2V or 1.35V only for all parts. The result is lower power consumption over DDR3 memory, for a cooler, quieter, more reliable system.
Stand out from the crowd and maximise heat dissipation with Predator’s signature tall heat sink, now in black. Its style complements the design of the latest PC hardware. HyperX Predator DDR4 is backed by a lifetime warranty, free technical support, and the reliability and expertise that make HyperX unbeatable.
