BT.com
Wishlist
Kingston 64GB 2400MHz DDR4 CL14 DIMM (Kit of 4) XMP HyperX Savage Blk
Kingston 64GB 2400MHz DDR4 CL14...
£442.04
35 in stock
£442.04
Add to wishlist
Delivery
Standard 1-3 working days
Marketing description is not available.
HyperX Savage - DDR4 - 64 GB : 4 x 16 GB - DIMM 288-pin
RAM memory
64 GB : 4 x 16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz ( PC4-19200 )
Latency Timings
CL14 ( 14-14-14 )
Dual rank, black heatsink, aluminium heat spreader, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), Black PCB, low profile heat spreader, sixteen banks, asymmetrical heatspreader , unbuffered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty ( Russia - 10 years )
64 GB : 4 x 16 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.36
Speed
Latency Timings
CL14 ( 14-14-14 )
Non-ECC
Module Configuration
2048 x 64
Chips Organization
1024 x 8
Voltage
1.2 V
Lead Plating
Gold
RAM Performance
SPD - 2133 MHz - 1.2 V - CL15 - 15-15-15 , Intel Extreme Memory Profiles (XMP) - 2400 MHz - 1.2 V - CL14 - 14-14-14
Colour Category
Kingston 64GB 2400MHz DDR4 CL14 DIMM (Kit of 4) XMP...
£442.04
Save on this ideal PC Build kit!
Save £9.16
£461.60
Scroll to top
