Kingston 60GB SSDNow V300 SATA3 2.5" 7MM solid state drive
Kingston 60GB SSDNow V300 SATA3...
Add to wishlist
Standard Due date unavailable
Kingston's SSDNow V300 solid-state drive is a cost-effective way to revive your computer. It's 10x faster than a hard drive plus more reliable, more durable and shock-proof. It features an LSI SandForce controller customized for Kingston and best-in-class components, and is available in kits with all the accessories needed for an effortless transition to the latest technology. For added peace of mind, it's backed by a three-year warranty, free technical support and legendary Kingston reliability.
Compressible Data Transfer (ATTO)
  • All capacities: 450MB/s Read and 450MB/s Write
Incompressible Data Transfer (AS-SSD and CrystalDiskMark)
  • 60GB -- 150MB/s Read and 50MB/s Write
  • 120GB -- 180MB/s Read and 133MB/s Write
  • 240GB -- 191MB/s Read and 142MB/s Write
  • 480GB -- 450MB/s Read and 208MB/s Write
IOMETER Maximum Random 4k Read/Write
  • 60GB -- up to 85,000/ up to 60,000 IOPS
  • 120GB -- up to 85,000/ up to 55,000 IOPS
  • 240GB -- up to 85,000/ up to 43,000 IOPS
  • 480GB -- up to 73,000/ up to 28,000 IOPS
PCMARK® Vantage HDD Suite Score
  • 60GB: 39,000
  • 120GB: 49,000
  • 240GB: 57,000
  • 480GB: 57,000
Kingston SSDNow V300 - solid state drive - 60 GB - SATA 6Gb/s
Solid state drive - internal
60 GB
SATA 6Gb/s
Data Transfer Rate
600 MBps
Shock resistant
69.8 mm x 100.1 mm x 7 mm
86 g
Microsoft Certification
Compatible with Windows 7
3 years warranty
60 GB
SATA 6Gb/s
Shock resistant
69.8 mm
100.1 mm
7 mm
86 g
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
450 MBps (read) / 450 MBps (write)
Maximum 4KB Random Write
60000 IOPS
1,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
Power Consumption
2.052 Watt ( active ) , 0.64 Watt ( idle )
Limited warranty - 3 years , Technical support
70 °C
Vibration Tolerance
2.17 g @ 7-800 Hz (operating) / 20 g @ 10-2000 Hz (non-operating)
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Kingston 60GB SSDNow V300
Reviewed by Caerdydd on 13/03/2013
Bought this a month ago. Put this into my m1330 xps dell, which dramatically boosted performance giving second life for the old (~5 years) laptop, despite the fact that the device does not work in full as it limited by my laptop (supports sata II only). Even with 1GB (as in my case) laptop speed performance is superb. So far works great, real value for money.
5* Excellent
Reviewed by Anthony Spargo on 24/09/2013
Bought this a few months ago for a dual socket Xeon server with two L5410s in, sadly only running on SATA II but doesn't seem to make a noticeable difference compared to SATA III, boots Windows 7 Pro in about 10 seconds. Would definitely recommend.
Scroll to top
