BT.com
Wishlist
Kingston 4GB IronKey S250 Basic FIPS USB 2.0
Delivery
Standard Due date unavailable
Designed specifically for enterprise, government and military customers that need high performance and reliability in their USB flash storage devices, IronKey Basic S250 and D250 flash drives meet the stringent Security Level 3 requirements of the FIPS 140-2 standard. IronKey Basic S250 and D250 drives meet the extreme performance and security requirements of some of the world’s most demanding organizations and are built from the ground up to be the world’s most secure flash drives. They’re equipped with strong hardware encryption and use the algorithm approved by the DOD for storing Top Secret data. A ruggedized, waterproof metal chassis helps protect S250 and D250 drives from the elements, and active anti-malware prevents USB threats from spreading. IronKey Basic S250 and D250 drives are equipped with a control panel localized into eight languages around the world.
IronKey Basic S250 - USB flash drive - 4 GB
USB flash drive
Interface Type
USB 2.0
Storage Capacity
4 GB
Hardware Encryption
Encryption Algorithm
FIPS 140-2 Level 3, 2048-bit RSA, 256-bit SHA, 256-bit AES-CBC
SLC NAND Flash
Microsoft Windows Vista SP2, Linux 2.6 or later, Microsoft Windows 7 SP1, Windows 8, Windows 8.1 / 10, Apple MacOS X 10.9.x - 10.11.x
5 years warranty
USB flash drive
Storage Capacity
4 GB
Hardware Encryption
Compatibility
Non-specific
Read Rate
Up to 31 MB/s
Write Rate
Up to 24 MB/s
Interface Type
USB 2.0
SLC NAND Flash
Password protection, waterproof, tamper-proof, ruggedized, metal body, Cryptochip
Limited warranty - 5 years
75 mm
19 mm
9 mm
25 g
70 °C
Scroll to top
