BT.com
Wishlist
Kingston 4GB HyperX Genesis DDR3 1600MHz DIMM 240-pin CL9
Delivery
Standard Due date unavailable
4GB 512M x 64-Bit DDR3-1600MHz CL9 240-Pin DIMM
Kingston's 512M x 64-bit (4GB) DDR3-1600MHz CL9 SDRAM (Synchronous DRAM) memory module, based on sixteen 256M x 8-bit DDR3 FBGA components. This module has been tested to run at DDR3 1600MHz at a low latency timing of 9-9-9-27 at 1.65V. The SPD is programmed to JEDEC standard latency DDR3-1333MHz timing of 9-9-9 at 1.5V. This 240-pin DIMM uses gold contact fingers and requires +1.5V.
Kingston HyperX Genesis - DDR3 - 4 GB - DIMM 240-pin
RAM memory
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz ( PC3-12800 )
Latency Timings
CL9
Unbuffered
Voltage
1.65 V
Lead Plating
Gold
Limited lifetime warranty ( Russia - 10 years )
4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9
Non-ECC
Unbuffered
Module Configuration
512 x 64
Voltage
1.65 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
Resources
The following resources are available for the Kingston 4GB HyperX Genesis DDR3 1600MHz DIMM 240-pin CL9
Scroll to top
