BT.com
Wishlist
Kingston 4GB DDR4 2133MHz Module
Delivery
Standard 3-5 working days
Kingston have been manufacturing high quality memory RAM components for computer upgrades for desktops, laptops, servers, motherboards and more for over 25 years with a keen emphasis on total quality. All memory chips are sent directly from the DRAM manufacturer to Kingston assembly plants to minimise handling and reduce the chance of damage and this ensures Kingston are involved in the total manufacturing process from start to finish. This Kingston KCP421SS8/4 4GB DDR4 2133MHz Non ECC Memory RAM SODIMM module has been part of that process. Kingston offers lifetime warranrty on all its memory modules to back up its assurance of quality. Kingston is involved in the DRAM process from the dicing of the wafer to encasing the integrated circuits and from assembling the module to testing the finished product meaning Kingston are involved in every part of the manufacturing process to ensure excelletn quality control.
Kingston - DDR4 - 4 GB - DIMM 288-pin
RAM memory
4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Unbuffered
Voltage
1.2 V
Lead Plating
Gold
HP P1N51AT, HP P1N51AA, HP T0E50AA, Lenovo 4X70K09920, HP M4Z83AV, Lenovo 03T7465, HP 798033-001, HP 834931-001, HP M4Z87AV
Limited lifetime warranty (Russia - 10 years)
4 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15
Non-ECC
Unbuffered
Module Configuration
512 x 64
Voltage
1.2 V
Lead Plating
Gold
Scroll to top
