BT.com
Wishlist
Kingston 4GB DDR3L DIMM 240-pin ECC Memory
Kingston 4GB DDR3L DIMM 240-pin ECC...
£43.47
10 in stock
£43.47
Add to wishlist
Delivery
Standard 3-5 working days
Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
Kingston - DDR3L - 4 GB - DIMM 240-pin
RAM memory
4 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11
Low Voltage, unbuffered
Voltage
1.35 V
Lead Plating
Gold
IBM 0C19499
Lenovo ThinkServer RS140 70F2, 70F3, 70F8, 70F9; TD340 70B5, 70B6, 70B7; TS130 1098, 1100, 1105, 1106; TS140 70A0, 70A1, 70A4, 70A5; TS430 0387, 0388, 0389, 0390, 0391, 0392, 0393, 0441; TS440 70AL, 70AM, 70AN, 70AQ
4 GB
Upgrade Type
System specific
IBM 0C19499
DRAM
DDR3L SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11
ECC
Module Configuration
512 x 72
Voltage
1.35 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
Lenovo ThinkServer RS140 70F2, 70F3, 70F8, 70F9 , Lenovo ThinkServer TD340 70B5, 70B6, 70B7 , Lenovo ThinkServer TS130 1098, 1100, 1105, 1106 , Lenovo ThinkServer TS140 70A0, 70A1, 70A4, 70A5 , Lenovo ThinkServer TS430 0387, 0388, 0389, 0390, 0391, 0392, 0393, 0441 , Lenovo ThinkServer TS440 70AL, 70AM, 70AN, 70AQ
£43.47
Save on this ideal PC Build kit!
Save £8.43
£62.69
Scroll to top
