BT.com
Wishlist
Kingston 4GB DDR3 1600MHz CL11 DIMM Memory
Kingston 4GB DDR3 1600MHz CL11 DIMM...
£42.68
1 in stock
£42.68
Add to wishlist
Delivery
Standard 3-5 working days
Kingston - DDR3 - 4 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - CL11 - 1.5 V - registered - ECC
RAM memory
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11
Single rank, registered
Voltage
1.5 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11
ECC
Module Configuration
512 x 72
Chips Organization
X8
Voltage
1.5 V
Lead Plating
Gold
£42.68
Save on this ideal PC Build kit!
Save £8.29
£61.85
Scroll to top
