BT.com
Wishlist
Kingston 4GB 2400MHz DDR4 ECC Reg CL17 DIMM 1Rx8
Kingston 4GB 2400MHz DDR4 ECC Reg...
£46.06
£46.06
Add to wishlist
Delivery
Standard Due date unavailable
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR4 - 4 GB - DIMM 288-pin
RAM memory
4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17 (17-17-17)
Temperature monitoring, single rank, On-Die Termination (ODT), Serial Presence Detect (SPD), sixteen banks, registered with parity
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
4 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.23
Speed
Latency Timings
CL17 (17-17-17)
ECC
Module Configuration
512 x 72
Chips Organization
512 x 8
Voltage
1.2 V
Lead Plating
Gold
Colour Category
Green
RoHS
£46.06
Save on this ideal PC Build kit!
Save £8.40
£65.28
Scroll to top
