BT.com
Wishlist
Kingston 4GB 2400MHz DDR4 ECC CL17 DIMM 1Rx8 Micron B
Kingston 4GB 2400MHz DDR4 ECC CL17...
£40.87
£40.87
Add to wishlist
Delivery
Standard Due date unavailable
Kingston ValueRAM Server Premier is designed specifically for mission-critical server systems that require maximum uptime and stability. Server Premier Modules are built using the same components every time and include advanced product change notification (PCN). PCN ensures ample time for qualification and testing at the customer site. With ValueRAM Server Premier, you can expect the same degree of reliability and performance that IT professionals worldwide have come to depend on from Kingston memory.
Kingston ValueRAM Server Premier - DDR4 - 4 GB - DIMM 288-pin
RAM memory
4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17 (17-17-17)
Temperature monitoring, single rank, On-Die Termination (ODT), Serial Presence Detect (SPD), sixteen banks, unbuffered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
4 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.23
Speed
Latency Timings
CL17 (17-17-17)
ECC
Module Configuration
512 x 72
Chips Organization
512 x 8
Voltage
1.2 V
Lead Plating
Gold
Colour Category
Green
RoHS, halogen-free
£40.87
Save on this ideal PC Build kit!
Save £8.29
£60.04
Scroll to top
