BT.com
Wishlist
Kingston 4GB 1600MHz Reg ECC 1Rx8 Single Rank Memory Module
Delivery
Standard 3-5 working days
Marketing description is not available.
Kingston - DDR3 - 4 GB - DIMM 240-pin
RAM memory
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11
Single rank, registered
Voltage
1.5 V
Lead Plating
Gold
Fujitsu Celsius M720, M730, R670-2, R920, R930; PRIMERGY BX620 S5, BX620 S6, BX920 S1, BX920 S2, BX920 S3, BX922 S2, BX924 S2, RX200 S5, RX200 S6, RX200 S7, RX300 S5, RX300 S6, RX300 S7, RX900 S2, TX150 S8, TX150 S8r, TX200 S5, TX200 S6, TX200 S7, TX300 S5, TX300 S7
4 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11
ECC
Module Configuration
512 x 72
Chips Organization
X8
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
Fujitsu Celsius M720, M720 PREMIUM selection, M720 proGREEN selection, M730, R670-2, R920, R920 PREMIUM selection, R930 , Fujitsu PRIMERGY BX620 S5, BX620 S6, BX920 S1, BX920 S2, BX920 S3, BX922 S2, BX924 S2, RX200 S5, RX200 S6, RX200 S7, RX300 S5, RX300 S6, RX300 S7, RX900 S2, TX150 S8, TX150 S8r, TX200 S5, TX200 S6, TX200 S7, TX300 S5, TX300 S7
Scroll to top
