BT.com
Wishlist
Kingston 4GB 1600MHz ECC Single Rank Module
Kingston 4GB 1600MHz ECC Single...
£39.80
14 in stock
£39.80
Add to wishlist
Delivery
Standard 3-5 working days
Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
Kingston - DDR3 - 4 GB - DIMM 240-pin
RAM memory
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11
Single rank, unbuffered
Voltage
1.5 V
Lead Plating
Gold
Lenovo ThinkServer TS130; TS430; ThinkStation C20; C20x; C30; D20; D30; E30; E31; E32; S30
4 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11
ECC
Module Configuration
512 x 72
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
Lenovo ThinkServer TS130 1098, 1100, 1105, 1106 , Lenovo ThinkServer TS430 0387, 0388, 0389, 0390, 0391, 0392, 0393, 0441 , Lenovo ThinkStation C20 4262, 4263, 4265 , Lenovo ThinkStation C20x 4266, 4269, 4272 , Lenovo ThinkStation C30 1095, 1097, 1136, 1137 , Lenovo ThinkStation D20 4155, 4158, 4218 , Lenovo ThinkStation D30 4223, 4229, 4352, 4353, 4354 , Lenovo ThinkStation E30 7782, 7783, 7821, 7824 , Lenovo ThinkStation E31 2551, 2552, 2553, 2555, 3688, 3690, 3691, 3695 , Lenovo ThinkStation E32 30A0, 30A1, 30A2, 30A3 , Lenovo ThinkStation S30 0567, 0568, 0569, 0606, 4351, 4352
£39.80
Save on this ideal PC Build kit!
Save £10.63
£58.97
Scroll to top
