BT.com
Wishlist
Kingston 4GB 1600MHz ECC 1Rx8 Single Rank Module
Kingston 4GB 1600MHz ECC 1Rx8...
£39.80
2 in stock
£39.80
Add to wishlist
Delivery
Standard 3-5 working days
Marketing description is not available.
Kingston - DDR3 - 4 GB - DIMM 240-pin
RAM memory
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11
Single rank, unbuffered
Voltage
1.5 V
Lead Plating
Gold
HP Workstation Z1, Z220, Z230, Z420, Z620, Z820
4 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11
ECC
Module Configuration
512 x 72
Chips Organization
X8
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
£39.80
Save on this ideal PC Build kit!
Save £16.94
£65.18
Scroll to top
