BT.com
Wishlist
Kingston 4GB 1600MHz DDR3L ECC CL11 SODIMM 1Rx8 1.35V Hynix D
Kingston 4GB 1600MHz DDR3L ECC CL11...
£34.94
10 in stock
£34.94
Add to wishlist
Delivery
Standard 3-5 working days
Kingston ValueRAM Server Premier is designed specifically for mission-critical server systems that require maximum uptime and stability. Server Premier Modules are built using the same components every time and include advanced product change notification (PCN). PCN ensures ample time for qualification and testing at the customer site. With ValueRAM Server Premier, you can expect the same degree of reliability and performance that IT professionals worldwide have come to depend on from Kingston memory.
Kingston ValueRAM Server Premier - DDR3L - 4 GB - SO-DIMM 204-pin
RAM memory
4 GB
Memory Type
DDR3L SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
1600 MHz (PC3L-12800)
Latency Timings
CL11 (11-11-11)
Temperature monitoring, single rank, eight banks, On-Die Termination (ODT), Serial Presence Detect (SPD), Low Voltage, unbuffered
Voltage
1.35 / 1.5 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
4 GB
Upgrade Type
Generic
DRAM
DDR3L SDRAM
SO-DIMM 204-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL11 (11-11-11)
ECC
Module Configuration
512 x 72
Chips Organization
512 x 8
Voltage
1.35 / 1.5 V
Lead Plating
Gold
Kingston 4GB 1600MHz DDR3L ECC CL11 SODIMM 1Rx8 1.35V...
£34.94
Save on this ideal PC Build kit!
Save £10.63
£54.11
Scroll to top
