BT.com
Wishlist
Kingston 4GB 1600MHZ DDR3L ECC CL11
Delivery
Standard 3-5 working days
Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
Kingston - DDR3L - 4 GB - DIMM 240-pin
RAM memory
4 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin very low profile
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11
Unbuffered
Voltage
1.35 V
4 GB
Upgrade Type
Generic
DRAM
DDR3L SDRAM
Speed
Latency Timings
CL11
ECC
Unbuffered
Module Configuration
512 x 72
Voltage
1.35 V
Compatible Slots
Memory - DIMM 240-pin
Scroll to top
