BT.com
Wishlist
Kingston 4GB 1600MHz DDR3 ECC Single Rank Module with Thermal Sensor
Kingston 4GB 1600MHz DDR3 ECC...
£37.08
12 in stock
£37.08
Add to wishlist
Delivery
Standard 3-5 working days
Marketing description is not available.
Kingston - DDR3 - 4 GB - DIMM 240-pin
RAM memory
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11
Temperature monitoring, single rank, unbuffered
Voltage
1.5 V
Lead Plating
Gold
Apple Mac Pro (Mid 2010, Mid 2012)
4 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11
ECC
Module Configuration
512 x 72
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
Kingston 4GB 1600MHz DDR3 ECC Single Rank Module with...
£37.08
Save on this ideal PC Build kit!
Save £10.36
£56.63
Scroll to top
