BT.com
Wishlist
Kingston 4GB (2 x 2GB) DDR3 1600MHz HyperX CL9 XMP
Delivery
Standard Due date unavailable
Kingston's KHX1600C9D3K2/4GX is a kit of two 256M x 64-bit 2GB (2048MB) DDR3-1600MHz CL9 SDRAM (Synchronous DRAM) memory modules, based on sixteen 128M x 8-bit DDR3 FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 4GB. Each module kit has been tested to run at DDR3-1600MHz at a low latency timing of 9-9-9-27 at 1.65V. The SPDs are programmed to JEDEC standard latency DDR3-1333MHz timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V. The JEDEC standard electrical and mechanical specifications are as follows:
  • JEDEC standard 1.5V ± 0.075V Power Supply
  • VDDQ = 1.5V ± 0.075V
  • 667MHz fCK for 1333Mb/sec/pin
  • 8 independent internal bank
  • Programmable CAS Latency: 5,6,7,8,9,10
  • Posted CAS
  • Programmable Additive Latency: 0, CL - 2, or CL - 1 clock
  • Programmable CAS Write Latency(CWL) = 7(DDR3-1333)
  • 8-bit pre-fetch
  • Burst Length: 8 (Interleave without any limit, sequential with starting address "000" only), 4 with tCCD = 4 which does not allow seamless read or write [either on the fly using A12 or MRS]
  • Bi-directional Differential Data Strobe
  • Internal(self) calibration : Internal self calibration through ZQ pin (RZQ : 240 ohm ± 1%)
  • On Die Termination using ODT pin
  • Average Refresh Period 7.8us at lower then TCASE 85°C, 3.9us at 85°C < TCASE . 95°C
  • Asynchronous Reset
  • PCB : Height 1.180" (30.00mm), double sided component
Kingston HyperX - DDR3 - 4 GB : 2 x 2 GB - DIMM 240-pin
RAM memory
4 GB : 2 x 2 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz ( PC3-12800 )
Latency Timings
CL9
Intel Extreme Memory Profiles (XMP), dual channel , unbuffered
Voltage
1.65 V
Lead Plating
Gold
4 GB : 2 x 2 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9
Non-ECC
Module Configuration
256 x 64
Voltage
1.65 V
Lead Plating
Gold
Compatible Slots
2 x memory - DIMM 240-pin
Resources
The following resources are available for the Kingston 4GB (2 x 2GB) DDR3 1600MHz HyperX CL9 XMP
Scroll to top
