Click to visit BT.com
BT.com
Wishlist
Kingston 4GB (1 x 4GB) DDR3 1333MHz Laptop SODIMM CL9
5.0*
Quicklinx: 7FRZWS00
Mfr#: KVR1333D3S9/4G
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR3 - 4 GB - SO-DIMM 204-pin
RAM memory
4 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1333 MHz ( PC3-10600 )
Latency Timings
CL9
Unbuffered
Voltage
1.5 V
Lead Plating
Gold
4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
SO-DIMM 204-pin
Speed
Latency Timings
CL9
Non-ECC
Unbuffered
Module Configuration
512 x 64
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
1 x memory - SO-DIMM 204-pin
Customer reviews
Write a review for the Kingston 4GB (1 x 4GB) DDR3 1333MHz Laptop SODIMM CL9 here!
Perfect for my mid 2010 iMac
Reviewed by Jason. Review Posted 20/08/2011
excellent! exactly the thing my iMac needed! installation was simple, took less than 5 minutes. and it works seamlessly! you can tell when you have a great product when you can just plug it in and forget about it. I'm now considering buying 2 more just to have the full 16gb :D
highly recommended! especially for iMacs
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
