BT.com
Wishlist
Kingston 48GB (3x16GB) 1600MHz DDR3L ECC Reg CL11 DIMM Intel Memory Module
Kingston 48GB (3x16GB) 1600MHz...
£411.62
£411.62
Add to wishlist
Delivery
Standard Due date unavailable
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR3L - 48 GB: 3 x 16 GB - DIMM 240-pin
RAM memory
48 GB: 3 x 16 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
1600 MHz (PC3L-12800)
Latency Timings
CL11 (11-11-11)
Temperature monitoring, dual rank, eight banks, On-Die Termination (ODT), triple channel, Low Voltage, registered with parity
Voltage
1.35 / 1.5 V
Lead Plating
Gold
Pricing Type
Intel Memory Validation Program
48 GB: 3 x 16 GB
Upgrade Type
Generic
DRAM
DDR3L SDRAM
DIMM 240-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL11 (11-11-11)
ECC
Module Configuration
2048 x 72
Chips Organization
1024 x 4
Voltage
1.35 / 1.5 V
Lead Plating
Gold
Compatible Slots
3 x memory - DIMM 240-pin
Pricing Type
Kingston 48GB (3x16GB) 1600MHz DDR3L ECC Reg CL11 DIMM...
£411.62
Save on this ideal PC Build kit!
Save £10.63
£430.79
Scroll to top
