BT.com
Wishlist
Kingston 480GB SSDNow V300 SATA 6Gb/s 7mm 2.5" Solid State Drive Kit
Kingston 480GB SSDNow V300 SATA...
£158.72
Hurry, only 2 left in stock!
£158.72
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Tuesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Get more life out of your computer and maximize your existing investment by replacing your old hard drive with a Kingston SSDNow V300 solid-state drive. It's the most cost-efficient way to dramatically improve the responsiveness of your system - and it's less disruptive than migrating your data to a new system.
SSDNow V300 features an LSI SandForce controller customized for Kingston and optimized for flash memory to deliver the utmost in quality and reliability from two leading SSD brands. Because it's made with solid-state components and has no moving parts, it's shock-proof and withstands drops and bumps.
Compressible Data Transfer (ATTO)
  • All capacities: 450MB/s Read and 450MB/s Write
Incompressible Data Transfer (AS-SSD and CrystalDiskMark)
  • 60GB -- 150MB/s Read and 50MB/s Write
  • 120GB -- 180MB/s Read and 133MB/s Write
  • 240GB -- 191MB/s Read and 142MB/s Write
  • 480GB -- 450MB/s Read and 208MB/s Write
IOMETER Maximum Random 4k Read/Write
  • 60GB -- up to 85,000/ up to 60,000 IOPS
  • 120GB -- up to 85,000/ up to 55,000 IOPS
  • 240GB -- up to 85,000/ up to 43,000 IOPS
  • 480GB -- up to 73,000/ up to 28,000 IOPS
PCMARK® Vantage HDD Suite Score
  • 60GB: 39,000
  • 120GB: 49,000
  • 240GB: 57,000
  • 480GB: 57,000
Kingston SSDNow V300 Desktop/Notebook Upgrade Kit - solid state drive - 480 GB - SATA 6Gb/s
Solid state drive - internal
480 GB
2.5" (in 3.5" carrier)
SATA 6Gb/s
Data Transfer Rate
600 MBps
Shock resistant, TRIM support, SandForce Driven, S.M.A.R.T.
69.8 mm x 100.1 mm x 7 mm
86 g
3 years warranty
480 GB
2.5"
SATA 6Gb/s
69.8 mm
100.1 mm
7 mm
86 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
450 MBps (read) / 450 MBps (write)
Maximum 4KB Random Write
28000 IOPS
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" or 3.5" (with included bay adapter)
Power Consumption
2.052 Watt (active) , 0.64 Watt (idle)
Software Included
Drivers & Utilities
3.5-inch bay adapter, 2.5" USB enclosure, 2.5mm mounting spacer
1 x Serial ATA cable - internal , 1 x Serial ATA power adapter - internal
Mounting Kit
Included
ISO 9001:2008
Limited warranty - 3 years , Technical support
70 °C
Vibration Tolerance
2.17 g @ 7-800 Hz (operating) / 20 g @ 10-2000 Hz (non-operating)
Other bundles
Kingston 480GB SSDNow V300 SATA 6Gb/s 7mm 2.5" Solid...
£158.72
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.60
£162.32
Scroll to top
