Click to visit BT.com
BT.com
Wishlist
Kingston 480GB HyperX 3K SATA 6Gb/s 2.5" Solid State Drive
Quicklinx: 8242WS00
Mfr#: SH103S3/480G
Essential accessories
Kingston's HyperX SSD combines the SandForce controller technology with premium NAND flash, reducing load times while increasing performance and endurance. It provides high-speed SATA Rev 3.0 transfer speeds for larger bandwidth, which power users require for advanced gaming, multitasking and multimedia computing power. Kingston's HyperX SSD lets users load games and applications faster, increase frames per second (FPS) and quickly transfer and edit large media files. It's cool, silent and requires less power and no additional cooling requirements.
When configuring the HyperX SSD partition, the user can choose between having the maximum available capacity for data storage or giving up a little space to increase performance and endurance. This additional space is called over provisioning on an SSD. The amount of performance and endurance increase depends upon the type of data being stored on the HyperX SSD. The more data that is MPEG, JPG, ZIP or ARC file types, the greater the benefit for this increased over provisioning.
HyperX SSD uses an advanced wear leveling technology that distributes writes evenly across all the flash blocks in the SSD to maximize overall drive endurance. Additionally, wear leveling ensures that the individual flash memory blocks are consumed at a very balanced rate, not to exceed a 2-percent difference between the most often written blocks and least written. This enables the HyperX SSD to provide the longest possible life for the user while maintaining optimal performance.
Kingston HyperX 3K - solid state drive - 480 GB - SATA 6Gb/s
Solid state drive - internal
480 GB
NAND Flash Memory Type
Multi-level cell (MLC)
2.5" x 1/8H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Shock resistant, built-in Wear Advanced Levelling, TRIM support, SandForce Driven, Garbage Collection technology, SandForce DuraClass, aluminium enclosure , S.M.A.R.T.
Enclosure Colour
Black, aluminium
70 mm x 100 mm x 9.5 mm
97 g
3 years warranty
480 GB
2.5" x 1/8H
SATA 6Gb/s
70 mm
100 mm
9.5 mm
97 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
540 MBps (read) / 450 MBps (write)
4KB Random Read
60000 IOPS
4KB Random Write
45000 IOPS
Maximum 4KB Random Write
48000 IOPS
Reliability
MTBF
1,000,000 hour(s)
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bays
1 x internal - 2.5" x 1/8H
Power Consumption
2.11 Watt ( active ) , 0.455 Watt ( idle )
Mounting Kit
Included
Enclosure Colour
Black, aluminium
3 years warranty
Service & Support Details
Limited warranty - 3 years , Technical support
70 °C
