BT.com
Wishlist
Kingston 32GB DDR4-2133MHz Reg ECC Module
Delivery
Standard 1-3 working days
Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
Kingston - DDR4 - 32 GB - DIMM 288-pin - registered
RAM memory
32 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Registered
Voltage
1.2 V
Lead Plating
Gold
Cisco UCS-MR-1X322RU
Limited lifetime warranty (Russia - 10 years)
Cisco UCS B200 M4 Entry SmartPlay, B200 M4 Performance Smart Play, B200 M4 Value Smart Play, B420 M4 Blade Server, C220 M4 Entry Plus Smart Play, C220 M4 Entry Smart Play, C220 M4 Rack Server, C220 M4 Value Smart Play, C240 M4 High-Density Rack Server, C240 M4 Rack Server
32 GB
Upgrade Type
System specific
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15
ECC
Registered
Module Configuration
4096 x 72
Voltage
1.2 V
Lead Plating
Gold
Cisco UCS B200 M4 Entry SmartPlay, B200 M4 Performance Smart Play, B200 M4 Value Smart Play, B420 M4 Blade Server, C220 M4 Entry Plus Smart Play, C220 M4 Entry Smart Play, C220 M4 Rack Server, C220 M4 Value Smart Play, C240 M4 High-Density Rack Server (Small Form Factor Hard Disk Drive Model), C240 M4 Rack Server
Scroll to top
