BT.com
Wishlist
Kingston 32GB 2400MHz DDR4 CL15 DIMM (Kit of 2) HyperX FURY Black
Kingston 32GB 2400MHz DDR4 CL15...
£206.54
More than 50 in stock
£206.54
Add to wishlist
Delivery
Standard 1-3 working days
Engineered and tested to deliver extreme performance, Kingston HyperX easily endures the most rigorous demands of any creative professional, gamer or PC enthusiast.
Kingston HyperX FURY - DDR4 - 32 GB : 2 x 16 GB - DIMM 288-pin
RAM memory
32 GB : 2 x 16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz ( PC4-19200 )
Latency Timings
CL15 ( 15-15-15 )
Dual rank, black heatsink, On-Die Termination (ODT), Serial Presence Detect (SPD), dual channel, Black PCB, low profile heat spreader, FURY asymmetric heatspreader, sixteen banks, Intel Extreme Memory Profiles (XMP 2.0) , unbuffered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty ( Russia - 10 years )
32 GB : 2 x 16 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.34
Speed
Latency Timings
CL15 ( 15-15-15 )
Non-ECC
Module Configuration
2048 x 64
Chips Organization
1024 x 8
Voltage
1.2 V
Lead Plating
Gold
RAM Performance
SPD - 2133 MHz - 1.2 V - CL14 - 14-14-14 , SPD - 2400 MHz - 1.2 V - CL15 - 15-15-15 , Intel Extreme Memory Profiles (XMP 2.0) - 2400 MHz - 1.2 V - CL15 - 15-15-15
Colour Category
Kingston 32GB 2400MHz DDR4 CL15 DIMM (Kit of 2) HyperX...
£206.54
Save on this ideal PC Build kit!
Save £9.28
£226.13
Scroll to top
