BT.com
Wishlist
Kingston 32GB 2133MHz DDR3 Non-ECC CL11 DIMM Kit of 4 XMP HyperX Savage
Kingston 32GB 2133MHz DDR3 Non-ECC...
£250.59
14 in stock
£250.59
Add to wishlist
Delivery
Standard 1-3 working days
Marketing description is not available.
HyperX Savage - DDR3 - 32 GB : 4 x 8 GB - DIMM 240-pin
RAM memory
32 GB : 4 x 8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2133 MHz ( PC3-17000 )
Latency Timings
CL11 ( 11-12-12 )
Dual rank, eight banks, aluminium heat spreader, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), dual channel, Black PCB, quad channel, red heat spreader, low profile heat spreader, asymmetrical heatspreader , unbuffered
Voltage
1.5 / 1.6 V
Lead Plating
Gold
Limited lifetime warranty ( Russia - 10 years )
32 GB : 4 x 8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.29
Speed
Latency Timings
CL11 ( 11-12-12 )
Non-ECC
Module Configuration
1024 x 64
Chips Organization
512 x 8
Voltage
1.5 / 1.6 V
Lead Plating
Gold
Colour Category
Red
Kingston 32GB 2133MHz DDR3 Non-ECC CL11 DIMM Kit of 4...
£250.59
Save on this ideal PC Build kit!
Save £9.25
£270.15
Scroll to top
