BT.com
Wishlist
Kingston 32GB 1600MHZ DDR3 ECC CL11
Kingston 32GB 1600MHZ DDR3 ECC...
£273.21
10 in stock
£273.21
Add to wishlist
Delivery
Standard 1-3 working days
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR3 - 32 GB: 4 x 8 GB - DIMM 240-pin
RAM memory
32 GB: 4 x 8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11 (11-11-11)
Temperature monitoring, dual rank, eight banks, On-Die Termination (ODT), unbuffered
Voltage
1.5 V
Lead Plating
Gold
32 GB: 4 x 8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL11 (11-11-11)
ECC
Module Configuration
1024 X 72
Chips Organization
512 x 8
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
4 x memory - DIMM 240-pin
Scroll to top
