BT.com
Wishlist
Kingston 32GB (4x8GB) DDR3L 1600MHz CL11 DIMM Memory
Kingston 32GB (4x8GB) DDR3L 1600MHz...
£279.00
£279.00
Add to wishlist
Delivery
Standard Due date unavailable
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR3L - 32 GB: 4 x 8 GB - DIMM 240-pin
RAM memory
32 GB: 4 x 8 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
1600 MHz (PC3L-12800)
Latency Timings
CL11 (11-11-11)
Temperature monitoring, dual rank, eight banks, On-Die Termination (ODT), dual channel, Low Voltage, quad channel, unbuffered
Voltage
1.35 / 1.5 V
Lead Plating
Gold
Pricing Type
Intel Memory Validation Program
32 GB: 4 x 8 GB
Upgrade Type
Generic
DRAM
DDR3L SDRAM
DIMM 240-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL11 (11-11-11)
ECC
Module Configuration
1024 X 72
Chips Organization
512 x 8
Voltage
1.35 / 1.5 V
Lead Plating
Gold
Compatible Slots
4 x memory - DIMM 240-pin
Pricing Type
£279.00
Save on this ideal PC Build kit!
Save £16.94
£304.38
Scroll to top
