BT.com
Wishlist
Kingston 32GB (4 x 8GB) HyperX Beast DDR3 2400MHz DIMM CL11
Delivery
Standard Due date unavailable
Unleash the Beast on your system. The vicious HyperX Beast features a dynamic heatspreader to maximize thermal dissipation for increased reliability. Plus it looks really cool and enhances any system. It's Intel XMP ready so higher-performing frequencies, timings and voltages are just a few clicks away. The Beast gets along well with Intel Core processors and the AMD performance and gaming processors. Put the Beast in your corner and crush your opponents - or just conquer your challenging workload.
HyperX Predator Beast - DDR3 - 32 GB: 4 x 8 GB - DIMM 240-pin
RAM memory
32 GB: 4 x 8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC3-19200)
Latency Timings
CL11 (11-13-13)
Heat sink, dual rank, eight banks, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), dual channel, quad channel, unbuffered
Voltage
1.65 V
Lead Plating
Gold
32 GB: 4 x 8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.83
Speed
Latency Timings
CL11 (11-13-13)
Non-ECC
Module Configuration
1024 x 64
Chips Organization
512 x 8
Voltage
1.65 V
Lead Plating
Gold
Compatible Slots
4 x memory - DIMM 240-pin
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* As expected
Reviewed by Bergamot Eng. on 23/09/2013
Works well, super easy to install as usually.
Comes in 2 plastic boxes containing 2 units each.
The two plastic boxes are boxed in a cardboard box between foam pads.
Scroll to top
