BT.com
Wishlist
Kingston 32GB (2x16GB) DDR3 DIMM 240-pin 1866 MHz/PC3-14900 CL13 1.5 V Registered ECC Memory Module
Delivery
Standard Due date unavailable
Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
Kingston - DDR3 - 32 GB: 2 x 16 GB - DIMM 240-pin
RAM memory
32 GB: 2 x 16 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1866 MHz (PC3-14900)
Latency Timings
CL13
Registered
Voltage
1.5 V
Lead Plating
Gold
Apple MF622G/A (x2)
Apple Mac Pro (Late 2013)
32 GB: 2 x 16 GB
Upgrade Type
System specific
Apple MF622G/A (x2)
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL13
ECC
Registered
Module Configuration
2048 x 72
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
2 x memory - DIMM 240-pin
Scroll to top
