BT.com
Wishlist
Kingston 2GB Module
Kingston 2GB Module
£26.86
Kingston 2GB Module
Kingston 2GB Module
17 in stock
£26.86
Add to wishlist
Delivery
Standard 3-5 working days
All Kingston® memory modules must perform properly to ensure maximum performance. Therefore, Kingston has developed an industry leading quality process to ensure that Kingston memory delivers superior quality, performance, and 100% compatibility with the computing system the module is designed for. Kingston, the world's largest independent memory manufacturer, has over 2, 000 memory products. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
Kingston - DDR2 - 2 GB - SO-DIMM 200-pin
RAM memory
2 GB
Memory Type
DDR2 SDRAM - SO-DIMM 200-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
800 MHz (PC2-6400)
Unbuffered
Limited lifetime warranty (Germany, Austria and France - 10 years)
Apple iMac
2 GB
Upgrade Type
System specific
DRAM
DDR2 SDRAM
SO-DIMM 200-pin
Speed
800 MHz (PC2-6400)
Non-ECC
Unbuffered
Compatible Slots
1 x memory - SO-DIMM 200-pin
Apple iMac
Kingston 2GB Module
Kingston 2GB Module
£26.86
Save on this ideal PC Build kit!
Save £8.43
£46.08
Scroll to top
