BT.com
Wishlist
Kingston 2GB DDR2-800 Memory Module
Kingston 2GB DDR2-800 Memory...
£26.53
£26.53
Add to wishlist
Delivery
Standard Due date unavailable
Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
Kingston - DDR2 - 2 GB - DIMM 240-pin
RAM memory
2 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
800 MHz (PC2-6400)
Unbuffered
Limited lifetime warranty (Russia - 10 years)
Acer Aspire E571, G7200, G7700, M1100, M1201, M1202, M1610, M1641, M1800, M3100, M3200, M3201, M3202, M3203, M3600, M3641, M3802, M5201, M5620, M5621, M5641, M5700, m5711, M7200, M7711, T630, X1200, X1300, X1301, X1700, X1800, X3200; Veriton M220, M221, M264, M265, M410, M420, M421, M460, S461, X270
2 GB
Upgrade Type
System specific
DRAM
DDR2 SDRAM
DIMM 240-pin
Speed
800 MHz (PC2-6400)
Non-ECC
Unbuffered
Compatible Slots
1 x memory - DIMM 240-pin
Acer Aspire E571-HE74, G7200 Predator Apache, G7200 Predator Commander II, G7200 Predator Defender II, G7200 Predator Defender VI, G7200 Predator Reaper II, G7700 Predator Conqueror II, G7700 Predator Crusader II, G7700 Predator Rookie III, G7700 Predator Sniper IV, G7700 Predator Thumper II, G7700 Predator Trooper IV, M1100-2B7Z_250, M1201-SA1620A, M1201-SD4450A, M1201-SD5400A, M1202-ED7450B, M1202-EF8550A, M1202-U1850A, M1610-4M7A - "VISTA", M1641-4M7Z OB 22"X, M1641-4R7Z, M1641-NE7Z, M1641-NR7G, M1641-SD2200A, M1641-VR7H, M1800-C2DE7500, M1800-PDCE5200, M1800-PDCE5300, M3100-FE7Z - "VISTA", M3100-QB7Z - "VISTA", M3201-B3600A, M3201-ED5400A, M3201-U3791A, M3202, M3202-B3800A, M3203, M3203-010 OB 23’’X, M3600-ZE7Z - "VISTA", M3641 - RET, M3641-S3501A, M3802, M3802 - PF7Z, M3802-7F7G, M3802-7F7R, M3802-7K79, M3802-7W7G, M3802-AS5300A, M3802-EQ8400A, M3802-SD5300A, M3802-U9062, M5620-1M7N - "VISTA", M5620-IE7U - "VISTA", M5641-3R7H, M5641-B5540A, M5641-ER71, M5700-B5771A, M5700-E5801A, m5711, M7711, M7711-3K7P, T630-6B62, X1200-B1781A, X1200-B1782A, X1200-B1792A, X1200-BE5000A, X1200-U1711A, X1200-U1794, X1200-U1794A, X1200-UD5400A, X1300, X1300-BD7550A, X1300-NF7Z OB 19’’X, X1300-U1801A, X1300-U1802A, X1301, X1301 - RET, X1301-5F7A, X1301-5F7A OB 23''X, X1301-5F7R, X1301-5F7S, X1301-5F7Y OB 23’’X, X1301-5F7Z, X1301-B1012, X1301-B1702, X1301-B1812, X1301-B9082, X1301-E1102, X1301-U1302, X1301-U1312, X1301-U9032, X1301-U9052, X1700-SD2220B, X1700-U3793A, X1800, X1800-E1232, X1800-ED5300A, X1800-EQ8300A, X1800-SD5200B, X1800-U9002, X3200-BR7A OB 22''X, X3200-ED5600A, X3200-U1790A, X3200-U3630A, X3200-U3792A , Acer Veriton M221, M265, M265-BE5400C, M265-ED5300C, M265-ED6300C, M265-ED7600C, M265-SC4500D, M265-SD2220D, M421G, M421G-ED250C, M421G-ED5000C, M421G-ED5600C, M421G-EQ630C, M460-ED5400C, M460G-ED7500C, M460G-ED8500C, S461-UD2220C, S461-UD5200D, S461-UD5201D, S461-UD7300C, X270-ED1400C, X270-ED5300C, X270-ED7400C
£26.53
Save on this ideal PC Build kit!
Save £8.29
£45.70
Scroll to top
