BT.com
Wishlist
Kingston 2GB 800MHz CL6 Module
Delivery
Standard Due date unavailable
All Kingston® memory modules must perform properly to ensure maximum performance. Therefore, Kingston has developed an industry leading quality process to ensure that Kingston memory delivers superior quality, performance, and 100% compatibility with the computing system the module is designed for. Kingston, the world's largest independent memory manufacturer, has over 2, 000 memory products. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
Kingston - DDR2 - 2 GB - DIMM 240-pin
RAM memory
2 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Speed
800 MHz
Latency Timings
CL6
Unbuffered
IBM 41U2978, IBM 41X1081
Limited lifetime warranty (Germany, Austria and France - 10 years)
Lenovo ThinkCentre A57; A61; M55; M55p; M57; M57e; M57p
2 GB
Upgrade Type
System specific
DRAM
DDR2 SDRAM
DIMM 240-pin
Speed
800 MHz
Latency Timings
CL6
Unbuffered
Compatible Slots
1 x memory - DIMM 240-pin
Lenovo ThinkCentre A57 , Lenovo ThinkCentre A61 , Lenovo ThinkCentre M55 , Lenovo ThinkCentre M55p , Lenovo ThinkCentre M57 , Lenovo ThinkCentre M57e , Lenovo ThinkCentre M57p
Scroll to top
