BT.com
Wishlist
Kingston 1GB Module
Kingston 1GB Module
Delivery
Standard Due date unavailable
Kingston is the world's largest independent memory manufacturer. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
This memory is designed for the following systems:
Apple iMac Intel Core 2 Duo 17-inch (Late 2006);
Apple iMac Intel Core 2 Duo 17-inch CD (Late 2006);
Apple iMac Intel Core 2 Duo 20-inch (Late 2006);
Apple iMac Intel Core 2 Duo 24-inch (Late 2006);
Apple iMac Intel Core Duo 17-inch (Early 2006);
Apple iMac Intel Core Duo 20-inch (Early 2006);
Apple MacBook 13-inch;
Apple MacBook Pro 15.4-inch 1.67GHz;
Apple MacBook Pro 15.4-inch 1.83GHz;
Apple MacBook Pro 15.4-inch 2.0GHz/2.16GHz;
Apple MacBook Pro 15.4-inch 2.16GHz/2.33GHz;
Apple MacBook Pro 17-inch 2.16GHz;
Apple MacBook Pro 17-inch 2.33GHz.
Kingston - DDR2 - 1 GB - SO-DIMM 200-pin
RAM memory
1 GB
Memory Type
DDR2 SDRAM - SO-DIMM 200-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
667 MHz (PC2-5300)
Latency Timings
CL5
Unbuffered
Voltage
1.8 V
Lead Plating
Gold
Apple MA346G/A, Apple MA837G/A
Limited lifetime warranty (Germany, Austria and France - 10 years)
Apple iMac; MacBook; MacBook Pro
1 GB
Upgrade Type
System specific
DRAM
DDR2 SDRAM
SO-DIMM 200-pin
Speed
667 MHz (PC2-5300)
Latency Timings
CL5
Non-ECC
Unbuffered
Module Configuration
128 x 64
Voltage
1.8 V
Lead Plating
Gold
Compatible Slots
1 x memory - SO-DIMM 200-pin
Apple iMac , Apple MacBook , Apple MacBook Pro
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Upgrade to Macbook 2.16 MHz
Reviewed by Anonymous on 21/02/2009
upgraded my macbook 2.16MHz with two 1GB modules. A very easy upgrade. Powered up the mac and the next thing you know is everything is working well with 2GB of RAM. Excellent value for money ... I wish I was brave enough to upgrade to 4GB since Kingston say its possible, but no mention on the Apple web site.
5* Memory upgrade for macbook and
Reviewed by Anonymous on 27/07/2006
The decription doesn't say but this is for the macbook and macbook pro. I installed it into my macbook (white 1.83 combo drive) and it recognised it straight away and is working well. I bought 2 to make it a matched pair. and the macbook seems to be much faster because of it.
Scroll to top
