BT.com
Wishlist
Kingston 1GB Module for NEC Powermate
Kingston 1GB Module for NEC...
£14.28
£14.28
Add to wishlist
Delivery
Standard Due date unavailable
Kingston is the world's largest independent memory manufacturer. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
This memory is designed for the following systems:
NEC i-Select D6610;
NEC PowerMate M Series;
NEC PowerMate ML450;
NEC PowerMate ML460;
NEC PowerMate VL260;
NEC PowerMate VL360;
NEC PowerMate DL K Series;
NEC PowerMate DL S Series;
NEC PowerMate DL T Series;
NEC PowerMate ML7 K Series;
NEC PowerMate MT C Series;
NEC PowerMate MT K Series;
NEC PowerMate VL6 G Series;
NEC WA1310 Workstation.
Kingston - DDR2 - 1 GB - DIMM 240-pin
RAM memory
1 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
667 MHz (PC2-5300)
Unbuffered
Limited lifetime warranty (Germany, Austria and France - 10 years)
NEC WA1310; i-Select D6610; PowerMate ML450; VL260; VL4
1 GB
Upgrade Type
System specific
DRAM
DDR2 SDRAM
DIMM 240-pin
Speed
667 MHz (PC2-5300)
Non-ECC
Unbuffered
Compatible Slots
1 x memory - DIMM 240-pin
NEC WA1310 , NEC i-Select D6610 , NEC PowerMate ML450 , NEC PowerMate VL260 , NEC PowerMate VL4
£14.28
Save on this ideal PC Build kit!
Save £8.43
£33.50
Scroll to top
